Radio Frequency wood Glue curing
24 Jan 2008
Clwyd
Many years ago, I worked for a 'reproduction furniture' company, my job was to make the panels, ie. plane down, glue and sash cramp the wood to make table tops, dresser sides etc. The company introduced a Radio Frequency device that cured the glue in seconds, allowing the cramps to be removed after about 10 minutes. this saved a lot of time (and sash cramps) allowing for greater productivity.
Now I find myself in need of something like this as I have to constuct a load of panels (1200 x 280) about 30 of 'em. I've been away from the tools for 15 years or so and am getting back into the job again. Does anyone know where I can get one of these portable RF machines to Hire or Purchase, or are there better solutions available to enable me to produce a load of these panels?
Purcahase price may be a bit high for a one off, don't know of anyone who will do hire.
I tend to use Titebond II Alphatic resin which can come out of the clamps in 1hr but should not be stressed for 24hrs.
Whats the thickness and type of the wood and is it just a plain glue joint or reinforced in any way?
Jason
22mm thick, straight joint, but I have thought about biscuit jointing perhaps.
Oof! That is a bit steep eh? I wonder how much they cost nearly 20 years ago when I used to play with one. I may just go with the Titebond II... and invest in a few more sash cramps. Thanks Jason.
At 280mm wide you should be able to clamp 4 at a time if you have 4ft clamps.
Jason
