Hi all,
I am having issues trying to work out how my heating and water systems all works so that I can use it best.
Just moved into a property which has a new system installed. valiant eco tec plus boiler and a Unistor cylinder in the garage. There is a drayton timer in the garage and a honeywell therm stat in the hallway. Most of the rads also have TRV's. I have read all the sites in trying to work this out, and I am not a diyer, and there are no manuals, or any that help.
Hot water is fine, the cylinder has this set at approx 60c and on off is via timer switch
q1 - what does the water temp setting on the boiler do then? currently set to approx 9 o clock, builder said leave it like this - (asked him in case he knew!) shld I turn this all the way down?
Heating - on off via timer, I have turned trv's in rooms that i do not use to the frost position, others are about 3, or 4/5 if cold. I understand that the hall way therm will decide how hot the air is in the hall way and once it reaches that setting, eg 20c, it will turn all the rads off, is this right?
q - what does the temp dial for the radiator on the boiler do? I noticed that the higher this is, the more hot the rads appear? and even the water?, although difficult to check in this weather!
I want to use this system to its most effective use, last quarter bill was £250! and I thought this is supposed to be more efficient.
I never notice the boiler going off, does this mean the hall way never gets to 20c?
Sorry for all the questions, all help appreciated.
