Hi people im newbi
The problem I have IS.... all 8 rads in the house take much longer to warm up and doesnt get really hot since the plumber balanced the system.
The conservatory rad also happens to be last rad away from the boiler is stone cold; all the other rads warm up nice and hot. Turned off all the other rads in the house and left the conservatory rad on and sure enough it did heat up quite hot, plumber then balanced the rad/system but had to sacrifice and turn off the kitchen rad in order for the 7 remaining rads to warm up but takes quite along time and doesn’t really reach hot temperatures. The plumber seems to think the boiler hasn’t the power the supply the final rad in the conservatory hence why he had to stop the kitchen rad in order for the conservatory rad to work but subsequently reduced the time and maximum temperature of the other rads in the house. The boiler that I have is a baxi solo2 sr.
Is there any truth to what the plumber is saying? If so any ideas to what type of boiler I should go for i.e. in terms of power output and a good manufacture that can handle between 8-10 rads?. Or is there any other solution?
The boiler is in the loft and has a storage water cylinder 1st floor cupboard
Any information would be very grateful.
Many Thanks
Naz
Many Thanks
Naz
