hi all
can you say if this is good/sensible
been raining a few days now - and three drips , fast dripping, coming in above top of a window frame for last 30 mins....
I went outside and looked at the window, and others on same side of the house - like the rest of the windows, (its an externally rendered wall, on solid brick surface) - EXCEPT there is on the left hand side, top, of window a can of coke size broken bit of render.
- window is flush with external wall if that matters
Guessing i should:
1 - pull th ebroken bit off
2 - i have a bag from other work, or ready made mortar - guessing i can use this, and apply to the area
well that's it - i know no more! should i not do above, its meant to rain tomorrow and next day - mix something into the ready made mortar, use something else, make a cup of tea and phone someone else..... and help much appreciated...probably a simple thing to you guys...
Guessing i should:
