I opened up my boiler (Worcester 280RSF) today to change a cracked spark electrode which was stopping the pilot lighting reliably. Nice easy job, and it lights instantly now instead of after a minute of trying.
But after removing the inner casing cover, I spotted large droplets of water dripping off the air distribution plate above the fan and small puddles of water on the flue hood assembly, around the gas valve’s flange which the main burner bolts to and around the CC pressure sensing nipples. The water had then dripped down onto the control box, making a mess of the self-adhesive labels on it. Luckily, there’s been no damage to anything in the control box.
I don’t think it’s water from the boiler as there’s no sign of water leaking from anywhere (including the primary HE) and system pressure is rock-solid at 1 bar. The AAV is newish and working properly. The pipes that run upwards to the rads are fine, and the wall it’s mounted on is bone dry.
The boiler’s been out of action for a few days so there hasn’t been any heat to drive off this moisture.
There was torrential rain here overnight, and so I’m wondering whether this is rainwater coming in. The boiler has the standard horizontal flue option, i.e. one 90 degree bend then about 300mm of flue going straight through the wall to the terminal). It’s a flat-roofed house with no overhanging eaves. The boiler was installed by a Corgi-registered fitter in 1994 and has been serviced annually, though always in the summer in very dry weather.
The combustion chamber always seems to have quite a few little leaves and insects in it when it’s serviced, so obviously stuff does work its way in through the flue.
Cheers.
Cheers.
