Hi all,
Carrying on with the renovation of our cottage, we've had floorboards up to replace/run pipes and cable as well as fit insulation.
Some of the old floorboards were knackered anyway and split as we lifted them so I have replaced with the same thickness boards where required.
The cottage is an old period property and such isn't exactly straight or level however there are probably 4/5 boards across the two rooms we have done that have a slightly raised edge/lip above the adjoining board. Not by huge amounts, but enough so you can't drag your foot across it for example with catching the raised edge. The issue is only on one edge of the boards and they are in different locations across the rooms.
We will be fitting underlay and carpet anyway so not too bothered about looks but what would be the best way to reduce the raised edges? Plane, sand? Something else?
I'm sure the carpet will cover the worst of it but if I can make them better whilst I can then that would be for the best.
Thanks all
Thanks all
