why do that? by the time you've figured out how too you could pick up a new one which has a warrenty, takes 2 minutes to change and will last years.Look up at Danfoss for the 103 then down to your supplier.
Or change it for a digital one
You might prefer to use a 103E7 instead. Digital instead of noisy clock, and separate control for each day. 103E5 is arranged 5/2 days. It fits the same backplate, so no work to do!
I've probably got one I can sell you. Not sure, cos I can only see the outside of the heap..
