Can anyone tell me why my (fairly) new Rangemaster has suddenly started cutting out on one burner/ it's LPG and it's the wok ring which cuts out if that makes any difference!
Thanks for any help!
Make sure the burner is clean and that the flame is enveloping the thermocouple tip. If this proves ok then it may be a faulty t/couple. If its under warranty call the makers.
Sometimes the clip becomes partially detached from the back of the gas tap and just needs pushing back on or its a warranty call for maybe a thermocouple or gas tap any way its an easy fix.
