Ravenheat RSF 84ET
9 Jul 2005
Yorkshire
Looked at this one and its got a leaking diverter valve, the rads sometimes come on when running hot water and the rads get really hot even when temp dial turned low on boiler.
Think new valve will fix first two, do you agree and then a CH thermister to fix the heating problem eh?
The things are that one the guy said if it needs a new boiler put one in. Well these are not good boilers, but does it reall warrant a new boiler?
The price of diverter valve ranges from £43.50 at eazyparts to £154.00 elseware, why such a great difference?
What do you guys think?
one a genuine part the other is a mock up
and changing diavert should cure the rad problem
but yer they are not the best boiler
The thermistors are common problems on these also so you may aswell change it whilst diverter valve is out, good luck, tricky on these boilers
