Ravenheat the radiators heat up when the hot tap is run
4 Jun 2009
Pembrokeshire
The problem seems to be getting worse and the radiators closest to the boiler are warming/heating up when I run the hot tap for the bath I would appreciate any suggestions. Thanks
You dont bother to say which ravenheat boiler you have!
Probably an aging one!
The manifold section of the diverter valve is probably jammed.
We would be replacing it although its a knuckle scraping job. We would be charging about £168.
Tony
Thats what I expected!
A knuckle scraping job!
If you cannot replace it yourself then it may be a good time to think about a replacement boiler.
Tony
