P
PrinceofDarkness
So (at last), it seems that you have a standalone RCD? In which case you should simply switch off the main switch on that adjacent Wylex fusebox in order to reset the RCD. Having done that, the RCD should reset if there's power to it. If it doesn't, then it needs replacement
By the way: does that green/yellow wire in your photo, lead to an indepedent earth stake?
Lucia.
Lucia.
