rcd consumer unit and radial cooker thing
30 May 2006
Hi, an anyone help?
I am having a kitchen fitted, my fitter has just informed me that on top of the consumer unit and RCD, I will also need to have a radial cooker thing (sorry for not being exact) for our range dual fuel cooker. He says this is going to be another £120 to do. Can anyone confirm if this is a reasonable price to pay for this work, which is on top of the £240 for the consumer unit with RCD?
The radial circuit will be because you have a large electric cooker that needs a high-amperage supply, with a thick cable and a high-rated MCB. The price is not unreasonable, but it is important that the person fitting it is qualified to self-certify his installation and issue you with a Completion Certificate which covers the new Consumer Unit and any electrical work in the kitchen (this is required by Building Regulations and will also probably be needed when you sell the house). Some kitchen fitters do electrical work but are not qualified. Some are. Ask him if he is a member of a self-certification scheme, and which one, and if he is going to provide you with a certificate. If not you might do better to get a proper qualified electrician in. If he says you can get the council building inspector in, that is true, but will probably double the cost.
Many thanks JohnD. The fitter is bringing an electrician in to do the work tomorrow, hopefully he can provide the documents you refer to. This is all very new to me, so thank goodness for the web!
