- Joined
- 27 Jan 2008
- Messages
- 27,543
- Reaction score
- 3,328
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Looking at the RCD there are many variations including auto resetting and with built in monitors as with the X-Pole.
One would also assume where someone presses the test button and it does not work they will get the RCD changed so visiting random houses is hardly going to give results which can be of any real benefit. If for example a new build estate was selected and all agreed to taking part in the survey then some control would be exercised as to where RCD's were changed.
My wife worked for market research firms for years and she would say how she could change the results just by the inflection in her voice. And clearly were one knows the research is for government some will try to alter the results.
As to the number of bypassed RCD's the question must arise did the faulty RCD's ever work? Clearly no post fitting checks were carried out or there could be no bypassed RCD's found. I am sure I am not alone in having to return faulty RCD's which on fitting did not work. In fact I have found the heavy cables used can warp the unit so causing it not to work as designed so the post fitting tests are very important.
The reports from contractors shows how the information was obtained from many sources and although it serves to show how important an Electrical Installation Condition Report is to be of any real value one needs two reports the PIR then 10 years latter the EICR and compare results so one knows it was all correct to start with.
