I recently had some electricians come round to move some plug sockets and replace old ones in preparation for new kitchen as well as change our fuse box.
They completed all of the work on day one, but said that they were getting strange readings of our earth and neutral? To get a certificate we would need it sorted. That's fine as it was probably a an unwise drill hole (previous owners) above two different sockets, one in the kitchen and one in living room.
They came the next day and did there bit and went. When I came home the power was off. Switched it on, an hour later off? This happened all that day? Weekend comes and it's fine all the time.
I then plaster over his repairs and everything dies and I can't re set the plug socket ring on the rcd side. So i thought his fix must have got wet. I take plaster off and cable protector off and find electrical tape covering a still damaged wire. The neutral had half of it's sheath missing on opposite side to earth wire.
I feel this was dangerous and was probably causing the rcd trip? Or was this acceptable??
The house is slightly damp and i did check all the appliances one by one. Just can't get why it was so random at first??
