RCD tripping
5 Feb 2018
Cymbeline
Hi - last Friday evening one of my two rcd tripped. I reset it and all was fine. At the time I noticed it was at the same time as my central heating programmer switched off the central heating upstairs. This Friday (last night) it did exactly the same thing at the same time. At the time only the up stairs heating was on which is controlled by a Honeywell 2 port valve. My heating downstairs is completely separate underfloor heating system it's individual controls, so unrelated - at the time this was switched off.
When the timer switched off the zone valve was still open a thermostat calling for heat - so it appears that when the zone valve closed the fault occurred. At no other stage through out the week has this happened at it seems very odd that it was exactly the same time on a Friday . The seven day programmer is set the same for every day but maybe it's an intermittent fault and just a coincidence?
My guess is that there is a fault with the zone valve micro switch caused when the power switches off? I'm not electrically qualified but thought that an electrical fault like this would more likely to occur when the micro switch turned on the circuit rather than turn it off?
Some help on this would be appreciated
Cymbeline, 5
Read more: https://www.diynot.com/diy/threads/rcd-tripping.501232/#ixzz5CcekdvPY
