I have an RCD protected mains supply that trips the RCD at 7:00 am exactly on some, but not all, mornings. I moved into this house a couple of mths ago, and initially it was tripping almost always on Mondays, but last week it tripped on Mon, Tue, and Fri.
Neighbours advise that previous occupiers had the same problem, ruling out my appliances. The house is 2 storey detached and 7 years old, so I doubt if any significant modifications to the electrics have been done since.
The RCD is a 30 ma type and self test button trips it ok. Its not connected to the lighting, which has its own set of CBs but no RCD. Power is 240v from underground supply.
I thought it may have been a fault with the evaporative cooler, but I unplugged that in the ceiling this weekend and on Monday the RCD didn't trip - I thought I'd nailed it! - but on Tuesday morn it tripped so back to the drawing board.
The house electrics include: Evap cooler and gas ducted heater (Brivis) both controlled from a wall mounted thermostat/controller. Electric oven, one electric element on the cooker, range hood, and automatic garden sprinkler system.
The sprinkler system controller is unplugged and not used.
The only timing system in the house that apparently preserves its time when power is interrupted appears to be the heating/cooling controller (maybe it has a battery backup?).
This is driving me nuts! I am trying to isolate the issue to one circuit now, by switching off CBs each morn just before 7am and watching for a trip, but due to the unpredictability of the trip, a failure to trip doesn't prove that I've isolated the fault.
Any help greatly appreciated, and FYI, I am located in Melbourne Australia.
