That obviously makes it less likely [typo corrected] that anything within' the cooker is at fault - suggesting that the most likely place for the problem is where the supply enters the cooker or somewhere else in the wiring of the cooker circuit.
That obviously makes it less likely [typo corrected] that anything within' the cooker is at fault - suggesting that the most likely place for the problem is where the rat enters the cooker or somewhere else in the wiring of the cooker circuit.
Brilliant! You guys are awesome. Thanks for the great advice John. I'm so glad this is in past and I can laugh about it. I was not laughing when I was force-pulling that sucker (but spelled with an "f") out by the tail.
It has in places. The middle inch or so of the very bottom blue is stripped bare. It's just the copper has tarnished as it must have been like that a little while.
Fair enough! There were, of course, other areas of gnawing along the length of my cable, but I photographed just that one bit because of the three bare conductors side-by-side - mainly as a means of illustrating that one should not feel too reassured by normal IR measurements (which, needless to say, that cable had)!
My cable was chewed all over the place, and also passed an IR test with flying colours ... We ended up rewiring in a combination of pyro or steel tube.
We used bare copper pyro, which I'm sure they could easily chomp through if they wanted but the lack of plastic seems to prevent them taking an interest.
Also pyro always fails safe if it's damaged which is a real plus as this was a timber building which spends much of it's life unoccupied.
I'm not so sure about that one. It can be a risk if not RCD protected clipped to wood. If the sheath gets pierced the IR will start to drop and at some point it has the potential to work as a heating element, cooking the wood its fixed too
