RE: Info on new rules
20 Aug 2013
Can you tell me if I build an extension of 5m (due to new permitted development rule) instead of a 4m one that I have permission to build, would I be likely to get a completion cert or could they make me knock it down and how likely would that be? Thanks
You can't just build it out 5m. You have to go through the prior approval scheme first, which involves consultation with your neighbours.
In essence, if they don't object, your project can go ahead, but the process take around 42 days.
Thanks Tony for reply. I thought the whole idea of permitted development was that the neighbours couldn't object? Is it part of the new changes that the neighbours now have this opportunity?
The idea of PD is that someone can build a modest extension with little impact on the neighbours to make them want to object
Something like an 8m extension could have much more impact, and so neighbours may want to comment
Anyway, the new rules are not PD, more of a half way/half-baked muddle
It isn't like normal permitted development; it's a 'half-way' house where, in return for the chance of a larger extension, your neighbour has a chance to object. So keep on good terms!
If the neighbour objects to 5m, you can still put in a normal planning application.
Or play it safe(r) and go for a 4m deep extension, where the neighbour cannot object on planning grounds.
