Re-lighting Optima FF50
12 Nov 2010
Buckinghamshire
Hello!
As yesterday was very windy, and today we have no heating, I think the pilot light has been blown out on our Optima FF50 boiler!
I have followed instructions to re-light the boiler (basically turn it all of and turn it all back on!), but with no luck as yet.
When turned on, the boiler does make what sounds like perfectly normal noises, a couple of clicks and a constant hum, but the pilot light never ignites.
I've checked the overheat reset button, and from what I've read on a previous post, it should just be a button with a cross on it, like a phillips screwdriver, and that is stuck in, so I guess it hasn't overheated.
Has anyone got any ideas on how I can get it running again? Any help would be much appreciated.
Cheers,
Harry
an optima ff50 has a auto pilot and should light on its own as long as there is a demand, buy the fact that the boiler is making a noise there must be a demand, if this model is sparking but still has no ignition there is either a lack of gas, check to see if other gas appliances are working, if thats the case then you may need to get someone out as you may be looking at a new gas valve :cry:
Thanks shorky, the gas hob is working fine, so the supply is good.
I'm hoping your :cry: doesn't = £££!
I did notice there was a fair amount of what looked like soot in the flue, I'm guessing the particularly strong winds may have blown some of it back up into the boiler, clogging up something somewhere!
Needless to say, I'll be getting someone out.
Thanks for your help.
Maybe the RGI who services each year for you as stipulated in the installation and servicing instructions will be able to sort it for you.
