I have my NEST working okay after installing myself with some expert help from these forums but as a glutton for punishment I have decided to re-locate the Heatlink to the airing cupboard upstairs (its next to the boiler in the kitchen at the moment). The problem is that when I wired the heatlink there were 2 connections to the live terminal on the old block, one obviously was the live feed for the programmer itself and the other one I did not worry about at the time just linking it straight to live again. The problem is if I re-locate then now I do need to work out what that feed is for so that I can re-connect at the wiring center upstairs (assuming it terminates there). Any idea what this would be for? It is part of the same 4 core cable that carries all the other Heatlink connections bar the HW satisfied which is separate cable. Thanks in advance...
