Rear window brake light: drops down, fixing is loose
16 Mar 2005
2001 Nissan Micra
The rear window brake light has slipped down. The fixing on one side has let go.
The fixing is a brass plate with holes, that locates with a rubber pad with nipples that is attached to the window.
It's very fiddly to get in place. I think you are supposed to turn the brass plate using a socket until it is place, then press.
Anyone done this successfully? Or is there a better method of fixing. Gaffa tape just drops off after a while.
Heat the inside of the car. Sandpaper the contact area and superglue
