    Dismiss Notice
Rear window LED light keeps falling off
Discussion in 'Car Repairs / Maintenance' started by mike004, 27 Mar 2012.
  1. mike004
    mike004
    16 Mar 2005
    483
    Thanks Received:
    14
    Country:
    01 Micra
    The overhead LED brake light assembly on the rear window keeps falling off on one side.
    The LED bar is held into position by a brass plate which locates onto a rubber square fixed to the window glass. A series of dimples on the rubber plate lock into corresponding holes in the brass plate. Maybe because the rubber is getting old, the joint with the brass plate keeps failing.
    I have tried strong glue, but it keeps failing. Probably because it is a rubber/metal joint exposed to strong sunlight and icy nights. Any ideas?
  2. Sponsored Links
  3. wotan
    wotan
    24 Dec 2007
    10,981
    Thanks Received:
    142
    Cheshire
    Country:
    From Halfords, buy a pack of numberplate fixing pads these are double sided adhesive pads, and provided both surfaces are cleaned, will stick well.
    Wotan
  4. mike004
    mike004
    16 Mar 2005
    483
    Thanks Received:
    14
    Country:
    Thanks, I'll check that out.
Loading...
Share This Page
