I have managed to get the alarm to text me but it still has com port 1 fault displayed? If I try to arm it says do I want to arm with faults.
In wintex
In the radio pad com port options
I have onboard digi com as com2400 module
com port 1 and 2 as nothing fitted
com baud rate 2400
expansion port nothing fitted
I did read the http://www.diynot.com/diy/threads/texecom-elite-24-com2400-sms-issue.417497/#ixzz3IhYOIwOs
Within this thread it was recommended to set up as follows
on board dig com 2400
com port 1 if using premier 24 set to com2400
if using elite 24 com port 1 nothing fitted, you should be able to use the com ip on here if its the elite 24.
but when I selected on board digi com2400 and com port 1 digi to com2400 and then tried to download to panel it stopped halfway and said there was a communication error. I then had a panic attack because I thought com port 1 was where my computer was connected. I retried several times to connect and when it did I changed to what I have said above
"I have onboard digi com as com2400 module
com baud rate 2400
expansion port nothing fitted"
Are these the settings from the other thread what I really need and my coms failiure was just a coincidence?
Again many thanks in adavnce,
Si
In wintex
com baud rate 2400
com baud rate 2400
Si
