- Joined
- 2 Jul 2024
- Messages
- 7
- Reaction score
- 0
- Country
Good day all,
I am seeking advice and recommendations on the best type of insulation and best practices for converting a summerhouse (essentially a glorified shed) into a functional and comfortable garden office.
The space will likely see year-round use, so maintaining a stable and comfortable temperature is my primary concern.
From my research, I understand that converting a shed into a garden office can be a divisive topic in some circles, often leading to heated debates. To be absolutely clear, I am not looking to ignite a flame war or delve into the pros and cons of starting with a shed as the base structure. I’m fully aware that it’s not an ideal starting point, but it’s the one I have, and I’d like to make the most of it.
Thank you in advance for your time and advice!
Additional Details About the Structure:
- Size: 10x10 ft (3x3 m approximately).
- Roof Beams: 5 inches (127 mm).
- Side Walls: 2.5 inches (63.5 mm).
Insulation Options I've Considered:
- PIR Rigid Foam Insulation
- Known for its excellent thermal properties and space efficiency. However, I’m curious about how to handle gaps and ensure airtightness effectively.
- Rockwool Insulation
- Appealing for its soundproofing and fire-resistant properties, though I understand it might require a vapour barrier to prevent moisture issues.
- Fibreglass Insulation
- A cost-effective option, but I’m concerned about its thermal performance and whether it’s the best fit for a structure like mine.
- Spray Foam Insulation
- Seems like a versatile solution with great thermal performance, but I’ve heard mixed reviews about breathability and potential long-term issues with timber frames.
Key Considerations:
- What is the most effective approach to insulating walls, floors, and ceilings, especially given the limited space in the walls?
- Should I prioritise a specific type of vapour barrier or breathable membrane to manage condensation?
- Are there any particular materials or techniques you’d recommend to maximise thermal efficiency and minimise heat loss?
