Recommended locks for front door
I haven't, but it was done at one of the properties I manage. The lock then becomes the weakest point, and either breaks off the back plate, or the stricker or bolt gives way.
A solid core door is a door blank with no hollows or card board inside, hence it being called a solid core door, made of wood.
Andy
OOI, what broke?
I have solid hardwood doors and frames, an intruder kicked one hard enough to activate the alarm sensor without damaging the door.
I also have a 44mm softwood FLB gate, it was kicked and started a split by the lock (I subsequently added a steel kickguard).
Both fitted with the same model of Chubb deadlock.
A British Standard Deadlock, of course. BS3621
I hope you haven't got a plastic door.
Here are a few. The Union is particularly good value.
https://www.screwfix.com/c/security-ironmongery/bs-5-lever-deadlocks/cat810326
If somebody tries to sell you a Eurocylinder lock, ask if it meets the BS.
Your home insurance company will have a leaflet of specification called "minimum standards of home security." It may be within the policy or on their website. If you email them they will doubtless send you a copy.
5-lever locks made to BS3621 are of course essential for a wooden door, but you can go a step further and find one with a 25 year guarantee. They tend to be used a lot, so may as well get a well made one.
