Hi Everyone,
This morning we had a major water leak in the town and the supply was cut off for approx 6 hours. Unfortunately my family had managed to drain both the boiler and the cold water. I switched off the central heating combi, which was running and waited for the supply to go back on. Tonight, there is a reduced flow from the hot water taps which stops after about 10 seconds. The header tanks are full and the pipes on the boiler are all hot. Do you thjink I have got a pressure lock in the tank on the feed side ?, and if so ,how can I fix it ?.
Yours in hope, Rick
Yours in hope, Rick
