- Joined
- 12 Jun 2005
- Messages
- 36
- Reaction score
- 0
- Country
Hello all. Need some advise on where to look next. I have been called to a Vaillant Ecomax Pro 28e that will not fire up when demanded. o fault codes on boiler.
When demanded the pump will only run sometimes. The 3 port valve was switching but now intermittantly. Even with the pump running the boiler still refuses to fire.
Voltage to the boiler measured at the wiring centre beneath is only 120V and should be 240. Talked to Honeywell but got interrupted. 240V at orange wire and sill 240V when grey & white are attached to permanent live.
I a planning to replace the 3 port valve but am I missing anything or on the wrong track.
Cheers
Stinker
Cheers
Stinker
