Reducing Pressure In Ariston Combi Boiler
7 Oct 2013
Edinburgh
Hi guys
First post here and I wouldn't be posting unless I was in desperate need of help
I've got an Ariston combi boiler which means I have to periodically top up the pressure . I had a bit of an accident which meant I didn't turn off the top up valve completely which meant the pressure went up to the red zone 3 bar and I need to reduce the pressure and wonder if there's anyway to do this ?
I read on the net that one way to do this is bleeding a radiator and tried this by bleeding two buckets full worth of water but the pressure has remained totally unchanged . Is there anything else I can do to reduce the pressure ? I should also add I'm totally useless when it come to DIY and plumbing and bleeding a radiator is an achievement in itself
There should be a drain tap somewhere on the system, often on one of the radiator valves. Attach a hose and open it up. You have fully closed the filling loop haven't you ?
You shouldn't need to regularly top up a sealed system. There is problem that needs sorting. Adding new water all the time will corrode your system from the inside out. Either that or its costing a small fortune in inhibitor.
Yes I certainly made sure the filling loop has been turned off . So just to confirm simply bleeding a radiator won't in fact reduce the pressure in the boiler ?
I've just had a look at my radiators and there doesn't seem to be anything that resembles a draining valve
you could do it via the bleed point on a rad. tho, it may take a while! make sure you have plenty of cloths/kitchen roll to hand to catch the water.
You THINK that you have turned off the filling loop.
But I don't think you have!
Turn off main stopcock and THEN bleed some water from the rads.
You may find that I speak sense!
Tony
The filling loop is certainly turned off . It was not turning it off completely that caused the problem a couple of weeks ago
And turn off the stop cock THEN bleed the radiators ? Ah that makes sense now
The expansion vessel may also need attention.
See the FAQ on this site.
"Turned off" does not mean just turned to the apparent off position! It means turned so that no water is flowing.
To avoid problems it needs to be sufficiently "off" that there are no drips for a 10 minute period !
Tony
I did double check the filling loop Tony and you may very well have been right about the filling loop . I did make sure after I saw your last post that the filling loop was turned off totally this now as opposed to " merely turned off "
Thanks for the advice to check the FAQ
