The thermostat (receiver) on my RT300RF is faulty, I can get a same for same replacement so I thought, locally. However when comparing the wiring diagrams on Salus web page, the latest model appears different, what I need to know is the equivalent wiring on the newer model compared to the faulty model.
The faulty stat shows the following wiring.
SL (Off) - Heat Off*
L – Live
SL (On) - Heat On
N – Neutral
The newer model shows the following.
1 NO Normally Open [N/O]
2 COM Linked Live feed (230V AC heating applications only)
3 L Live feed (230V AC)
4 N Neutral
The L & N are obvious, but would appreciate explanation as to what wiring on the new model relates to those on the faulty model.
L – Live
SL (On) - Heat On
N – Neutral
4 N Neutral
