Hi
On a 9 inch brick wall of a 1919 house, on the ground floor, I have some penetrating damp coming inside due to water getting behind damaged render. I intend to cut the render horizontally 6 feet above the ground, and remove the lower 6 foot of it.
The brickwork is likely to be damaged. I will dub up any damage to bricks with a concrete mix, and repoint as necessary, and finally apply a water-repelling breathable paint.
My concerns are:
- Given that I cannot work continuously, the wall may be exposed to rain (its facing SW hence takes rain head-on) for a few weeks. Should I be concerned about rain soaking into the wall (and penetrating to the inside) before I can apply the paint ? - should I attempt to protect the exposed lower section of wall from rain, and whats the best way ?
- Is there any breathable water repellant compound that can be used on damaged non-smooth brickwork ?
- Is there any particular mix most suited to dubbing out damaged bricks ?
- Should I be particular about the mortar used when pointing ? (given that the original mortar was probably lime based?)
- Should I think of applying a bead to the bottom edge of the remaining render in an attempt to deflect rain from the wall below ?
My concerns are:
