removing a ceramic tile whole.
29 May 2007
Gloucestershire
I have a situation where I have a cracked tile, which I cannot find a replacement. I am thinking of trying to remove a tile from under a unit and using that to replace the damaged tile. Any ideas?
gcol is right, if the tiler did a good job, unless you are very very very very lucky.... :)
Press on all 4 corners of each tile under your units, and see if you can find one that rocks, if you do, by some miracle, you may be able to lift it.... :D
Almost certainly though, that after you have tried this , all you will do is.... :cry:
