Removing a radiator for good.
8 Sep 2005
So in past DIY career I have successfully replaced a radiator :roll:
I now want to remove a disused radiator that some previous owner installed in the boarded loft room (long story). It was working years ago but I have turned it off at the valve and never used it.
The question is I now want to remove it entirely and just want to check what the best idea is for termination. The Rad is attached to a combi boiler central heating system so is part of a sealed loop. Would it be correct to simply drain the loop off and then terminate the piping under the floor level. Or do I connect the pipework together i,e the supply and return to preserver the loop?
Any help appreciated or if you know of a HOWto page please direct me there
Harmonia
Harmonia,
Sounds like a plan. You should'nt need to drian the whole system, just enough to empty the rad in question and its pipework.
Best If you can cap off as near as possible to where the supply pipes are teed of the loop.
If you're confident enough use solder fittings, failing that get som compression ends.
Hope that helps.
Rico
Thanks Rico. I have used solder in the past and prefer it to compression!
One thing so I would be better to terminate rather than connect the supply to the return to preserve the loop?
Harmonia,
You're welcome.
It all depends on how the rad is piped up.
Is it a continuation of the central heating circut or is it teed in to the flow and returns.
Rico
Thanks. I think more likely it was tee'd off as the rad was installed after the original Central Heating was installed. Reckon I need to go and investigate the pipework. Have a good weekend
