Removing adhesive underlay from oak flooring
26 Sep 2008
Staffordshire
I won 40 square metres of solid oak flooring on Ebay,not nailed or glued but has 'Elastilon Basic' self adhesive underlay stuck to the underside.
I can scrape most of it off with a paint scraper,but this leaves a layer of very sticky residue I don't know how to remove.
Is there an easy way to get this stuff off without damaging the oak?
All I can suggest is to experiment to find a solvent- including asking the company.
I bought old parquet and went through several tests to find a solvent for the bitumen that had been used as glue. Eventually I found that white spirit worked - but wickes "white spirit substitute" did not.
I still have some left in the shed and may try making a jig on a small bandsaw to remove a very small amount off the bottom. The important bit would be to remove a consistent amount and end up with blocks the same size.
I also looked at a cheap Amazon desktop planer but suspected that machining the bottom off might gum up the machine before the task was done. I planned on sacrificing the machine anyway as it was circa £100.
40 sq m is quite a lot so it has to be sustainable
Take it to a wood mil and they have a machine which will take 3mm off the bottom.
I find lighter fuel will disolve many adhesives, or cover it in talc and leave it on.
Acetone is pretty good for glue removal but with 40 sq m to do talc and batten sounds much easier :)
