Removing air from combi Ch system
15 Mar 2006
Tyne and Wear
Hi ive recently drained down the system and want to be sure there is no air trapped within combi/rads
Ive filled it back up and bled all rads and conmbi to 1bar
is this basically how its done, would all air in system eventually rise to rads and not sit in pipework/combi
Kev
yes, should..some combi's need pump bleeding, but if all sounds ok and works then your done. some inhibitor is good if your not going to drain down again soon
Heat exchanger might have a bleed or an auto air vent on the boiler which should normally be closed after commissioning may need to be opened for a while
