Removing chimney breast and securing stack
10 Mar 2011
Denbighshire
Hi, as per the title, I'm considering removing an unused chimney breast in the dining room and a 1st floor bedroom of our semi.
I called the local council to ask them what I should do. They told me to contact a structural engineer to have a look to see what needs to be done.
The engineer told me the stack can not be secured in the loft and that a steel beam(s) will have to be placed across the ceiling of the first floor bedroom. It will hang down 20cm and come out 40cm from the wall. I am not at all keen on this idea.
I can not understand why nothing can be done in loft. The stack is a zigzag shape and seem to be sitting on a concrete slab which goes through the dividing wall.
Outside photo on the stack from outside: Click them to enlarge
Chimney breast in 1st floor bedroom:
Photo of the chimney in the loft:
Photo of right side of the water pipes seen in the photo above:
Photo of left side of the water pipes seen in the photo above: (shows the concrete slab)
Photos of the underneath of the concrete slab:
What do you guys think? Any advice?
Many thanks
1. quote more from the SE report - reasons for ...
2. clear away chattels from obscuring the loft stack base and do more photo's
3. research on gov.party wall etc. and on this site and, say, screwfix.com forum
4. check with your neighbour, the condition of their stack, your proposal and the concrete slab on their side.
5. whats the condition and thickness of the party wall in the loft?
6. be more clear about the "concrete" slab
