Removing gloss paint off a fireplace
8 Feb 2011
Yorkshire
What is the best way to remove gloss paint off a victorian(ish) fireplace. It is painted up to the wooden surround and right up to the mantlepiece. Beneath the paint are small red bricks.
Heat gun and scrape, or messy Nitromors :?:
i favour heat gun - nitro only on things that can be done outside , my head is very susceptible to chemicals :wink:
I suggest you remove as much paint as possible with a heat gun then finish off with a chemical stripper and a small brush. This will get into any ornamental scrollwork much better than a scraper.
Either way, its a tedious job.
Thanks to all. Will be going back to see if they are a type of engineering brick, ...... they looked it.
I will clean a brick and then see if it is worthwhile doing the lot.
