Removing Howdens Kitchen wall cabinets
3 Jan 2016
Hi, We want to take down some Howdens wall units and cannot work out how to remove them. There is a white casing in the corner with screws but we cannot undo them, does anyone know if a specific tool is needed.
Those screws are for adjusting the alignment, not for holding up the cabinet.
They should just lift off, as long as there are no extra fixings at the bottom and not 'glued' in place with silicon/grout/etc.
turn the screws facing he front a little to slacken the hooks.
the fastenings I think you mean are adjustable to draw the hooks tight to pull the cabinet to the wall, it will be easier to lift off if you slacken them.
ae235
the chrome hook protrudes through the back of the cabinet and hooks onto the lip of the steel plate that is fastened to the wall.
there are other, less common, designs
