Sorry if this is long and confusing but im a very confused atm.
Im trying to remove three lights, each controlled by individual switches, and put in a central light operated by one of the current switches.
I have a central light in the kitchen (which im not touching) then an understairs cupboard and downstairs toilet, with a slight passage between kitchen and two areas with another light.
Im knocking down the walls to make it into a kitchen diner and want to remove the cupboard, toilet and passage light, then relocate one centrally running from the cupboard switch. The other two switches are on walls I intend to remove.
I've remove all the lights and switches to look at the wiring. Every switch has two wires going into the top and one out of the bottom. Every light has one live and two neutral.
I've removed the floorboards from rooms above and it seems there is a live wire coming from the kitchen light to the toilet light. One of the neutrals is going to the switch, the other to the passage light (which seems to be that ones live wire). The switches and the cupboard all seem to be linked via these neutral cables??
There is also another live wire i've identified connecting to the cupboard light, coming from the living room direction.
It seems like a bizzare set-up to me. Its a 1940's ex-council house.
I was going to use and reposition all the connections from the cupboard light for my new light, as im using that switchs, the connect in the other live wire from the toilet light. Then hopefully all the other lights and switches in that group will be disconnected and i only need to remove the wires.
Is this right? Does any of that make sense?!
