    Dismiss Notice
Removing paint from exterior stone walls
Discussion in 'Building' started by willtd, 20 Aug 2004.
  1. willtd
    willtd
    16 Jul 2004
    57
    Thanks Received:
    Country:
    Hi
    I recently took down an old porch from the front of my house (before it fell down), and now the wall around the door is covered in white paint and looks stupid!
    I have tried nitromorse and it won't look at it. What can I use to remove this paint from the stonework?
  2. big-all
    big-all
    12 Jul 2004
    18,109
    Thanks Received:
    1,384
    Surrey
    Country:
    you could try a rotary wire brush in your drill
    but be carefull if its old weatherd bricks may look
    worse if you finnish up with clean lines
    i am surprized nitromours didnt work did you give
    it long enough!!!!!!!!!!!!
    big all
  3. Sponsored Links
  4. Slogger
    Slogger
    26 Jun 2004
    1,680
    Thanks Received:
    3
    Country:
    nitromorse wont work very well on water based paints
    r the rocks painted with emulsion ? test a bit peel a bit off and try to burn it with a match or lighter if it wont burn then u have emulsion based = jet wash
  5. TexMex
    TexMex
    8 Jul 2004
    1,525
    Thanks Received:
    2
    Essex
    Country:
    Have you tried a pressure washer?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
