If it is an enamel bath, are you sure it is a burn? Or is it rust coming through.
Removing the first tile has to be done carefully, after one has been removed, should not be a problem to remove the rest. I would score it with a diamond tipped cutter, then lightly tap with a hammer and chisel.
