Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
What's the most effective way to remove tiles from a wall. The old tiles on my bathroom wall are so well stuck that using a hammer and chisel is taking me ages to chisel them off inch by inch. Would it be best for me to hire a light pneumatic drill?
You could try sliding the claw part of a claw hammer down the wall to flick them off. Failing that, get/borrow an sds dril with a rotational lock and use a wide chisel bit. It's worth the investment in actually buying one, they really are 10x better than a regular hammer drill.
Be prepared to make the wall good when you've finished though. You'll probably need to patch the wall in places.
Good luck,
Gcol
i tried using a wide chisel bit with my sds drill but this was less effective than the hammer and chisel. I don't really understand how this could work since the hammer drill is still effectively doing a rotating drill type action rather than a hammer action pounding against the tiles. has this worked for you Gcol? maybe i'm doing it the wrong way.
