Rendering BBQ ??
1 Jun 2019
I have built a base for my pizza oven and was planning to add a BBQ / work top. I have used breeze and want to render it to match the house. My question is will it be ok to render the BBQ or will the heat cause issues ???
It can do.
Any air bubbles in the render could expand with the heat and blow the render off the wall, with some force!
Woe betide anyone in the way at the time.
I have seen photos of some rendered , just wondered if there was a specific way of doing it ??? maybe they have just accepted the risk
Are you likely to have guests or kids about? Would they be aware of the risk, and would they accept it?
S&C render is often used inches from woodburners without issue so it’s generally considered ok with high temperatures. Never heard the “blow the render off the wall with some force” one before.
It’s probably the British climate that’ll ruin the render first, as sadly every day isn’t like today...
Fair comment, but "inches from the fire", and "in contact with the fire" is sufficiently different to ring alarm bells.
With a rendered BBQ, the fire could easily be in direct contact with the render.
