I've just had a chemical damp proofing done today which I probably didn't need. I asked the guy how I should re-plaster the walls and he said to use a 3:1 sand/cement mix with a waterproofer additive. I've been reading a fair bit about this stuff and I keep reading that a lime based render would be better as it allows the bricks to breathe? Would this be correct and if so what exactly do I need to buy, as there seems to be different types (hydra-this, hydra-that), and what mix should I be using?
The property is a brick victorian terrace. I'm not going to do this for a while as I want to see if the this chemical damp proof has actually done anything first, but I want to make sure I do it properly.
Thanks in advance.
Thanks in advance.
