Rendering sand?
11 Oct 2005
Bournemouth
Getting warmer so got some rendering jobs lined up.
As a point for discussion, I'd be grateful for any comments, advice, experience as to the best (most workable / best finish etc) sand to use for external render and where to get it.
(i.e. washed sharp, sharp/soft mix - what ratio? etc)
PS. Anyone used the plastic beads and what are the pros and cons over stainless?
Many thanks
PPS I won't be using PVA this time.
I get the sand for my plasterer from a local aggregate supplier. It is between building sand and sharp sand, called plastering sand.
That is what we use as he prefers it
Thanks,
I have found that different merchants give you different sand when you ask for plastering sand. Some too sharp others too soft. Pot luck I suppose. :roll:
