- Joined
- 15 Jan 2025
- Messages
- 135
- Reaction score
- 4
- Country
My favourite lamp isn't working right, it randomly cuts out if the cable isnt held at the right angle.
After some close inspection, i have identified the break. About a millimetre wide, the cable sheath is pierced and the copper wire within is presumably damaged. If i bend it in a loop so that the damaged part closes, and use a peg to hold it that way, it works reliably, so this isnt a huge priority, but that is mildly inconvenient
I know how this happened, i was working on sanding and repainting a door recently, took it off the hinges and lay it down, but i didn't notice that the lamp's cable was underneath the edge of that door (i was using it as a work light), and the weight pressing into an edge caused this damage to the wire
I would like to repair this, if possible. I looked into buying a replacement, it'd cost £35, this is a flexible lamp from ikea that i can't find any cheap alternatives for. I would rather not spend that
But moneysaving aside, half the reason i do DIY is to learn and develop new skills, its a hobby as much as a practical thing, so i'd like guidance and advice in fixing this
I don't have any experience with electrics, although i did study the basics in school, and my grandgfather was heavily into it, he demonstrated soldering on a few occasions, and i have lot of tools. For now i've wrapped the broken section in a bit of electrician's tape for safety, though this is not rigid enough to hold it in a functional position
I would intuit the repair process goes something like...
Identify the broken part (done)
Strip away the cable sheath carefully (with a blade, or pliars? not sure what to use)
Solder the broken cable together wih some kind of metal (i don't have a soldering iron, but they are cheap)
Resheath with electrician's tape for safety
Am i near the mark?
I'm not sure what kind of metal i'd use for the soldering, or how to strip the cable, advice would be appreciated
Am i near the mark?
