hello
I have a two story house and the radiators need to be replaced. I need to replace the radiators, valves and cut the pipes to fit the new radiators.
I have a loft tank, boiler upstairs and also a tank (I believe it is the Central Heating Tank) on the ground floor.
I'm thinking of following these steps:
- Turn off the central heating and Hot water system
- turn off the boiler
- turn off the stop cock to prevent water entering the sytems
- stop the small tank upstairs from filling up with water (tie up the ball in the cistern)
- drain the system through the radiator at the lowest point
- once completely drained I can then remove the radiators, cut the piping to fit the valves and replace with new radiators.
I would then repeat the steps above in reverse order to fill back up the system.
Have I missed anything ??
I'm worried I'm oversimplified this of course so I'm looking for someone to confirm or more importantly let me know if there are any other 'tricks' or tips to watch out for when doing this. Any suggestions ??
please help - DIY is something I toy with but don't want the wife to not be able to have a shower or have the boiler damaged at the end of all this..
many thanks.
many thanks.
