Replace HDMI Male Plug or alternatives
8 Jan 2014
Surrey
Briefly, in wall cable run with damaged end plug. I am pretty handing with fitting connectors, done RJ45 before, also quite handy with a soldering iron but there seems to be very few male HDMI plugs. Some on Amazon have screw down terminations but come from china so 3 weeks wait....
Another alternative maybe to cut off a lead and solder / splice conductors and heat shrink. It would be behind the TV.
Anyone with specific experience they could share? Many thanks
There are solder tag HDMI plugs on Amazon. There'll probably be some on Ebay too. There are also versions with the screw terminals built in to the back of the plug. Here's a link.
Whether you can use a solder tag plug depends heavily on the metal that the cable's conductors is made from. Bare off some of the insulation and scrape the bare metal surface. If it's still copper coloured then you're good to go. However, if you find it looks shiny silver then chances are it's aluminium with just a surface flash of copper. That's no good. In that case a screw terminal plug is your solution.
Be careful not to mess around with the individual conductor lengths. This is because HDMI relies on sending three data signals plus a timing signal all in sync with each other to describe each pixel of the picture. The lengths of the individual conductors can change the relative timing. Also, the higher the resolution of the signal then the more critical the timing and so the much smaller length changes have a big effect.
These plugs are between £8 and £15 on average. That's a lot cheaper than breaking the wall open and then making good after. Bottom line; it's worth a shot. If it works, then great. If not, then at least you know you've tried and the cost to do it wasn't a lot.
Going forward, next time you do an install, make sure to put the cable in to some conduit in a way that makes it easy to pull and replace should the need arise.
If this or any other reply was helpful to you, on each one please press the THANKS button which appears when you hover the mouse pointer near the Quote Multi-quote buttons.
Yes, thanks really helpful. So therefore splicing a HDMI cable to the end of the damaged cable plug end is probably not a great solution of the conductor lengths are fairly critical?
Thanks very much for the detail.
