Replace Singular Glued Floating 22mm T&G Chipboard
24 Jun 2022
I need to remove the corner board of a 22mm t&g chipboard floor where I've already glued the tongue and groove. It's a floating floor so it's on top of some PIR.
I need to level the surface underneath the PIR as there's some bounce I'm not happy about.
Is this even possible to do? I can multitool or circular saw the board out as the one I need to remove is in the corner, but obviously I'll lose the t&g.
How do I attach this back to the main floor? Can I just D4 glue the newly cut sides and butt join? I'm hoping this would work as it should all be supported by the PIR below and the glue is really just there to hold the board in place.
Any suggestions would be greatly appreciated.
Sure. If you're really bothered that the grand piano being rolled into that corner will cause them to separate again you can channel out the PIR enough to get a couple of flaps of OSB/similar glued+screwed to the underside of the p5 spanning the joint
