Replace timer for Vokerra Excell 80SP
10 Mar 2008
Bradford
Hello
Can anybody point me to a suitable replacement timer for a Vokerra Excell 80SP combi boiler. I am looking for a 7day digital timer.
The current boiler controls are located on the front panel of the boiler, it is my intention to run a digital timer to a more accessible location. I am looking for a compatible replacement.
I was under the impression that any timer with the standard "backplate" will suffice as long as I wire it correctly and set the timer to "10" it should work. Or is there more to it than this.
I would recoment a Danfoss TP 5000 programmable roomstat. It will give you time and temperature control as well as frost protection over seven day
Hello
Thanks for the reply, I am actually looking for a timer. I want to independently control CH & HW.
Would a Siemens RB29 suffice?
You do not use two channel programmers to control combi boilers.
First boiler control knob has a position where power is turned off (never leave the boiler in this position), next position power is on but boiler function are off,next- tap symbol is for summer setting where RUNNING a hot tap runs the boiler (No timer fitted to control this function as you do not have any connections that allows this). Final position is winter setting where the programmer controls the boiler to heat radiators.
You are already in need of a timer. Take an extra step and fit aforementioned unit to give you added function and fuel economy. Fitting a timer alone is a job half done.
DP,
Thankyou very much for your answers - I have a couple of further questions now though ... sorry !!
I thought I would need 6 channels (hw on/off, ch on/off, HW & ch on/off).
My boiler has 3 switch settings - A 'O' which I presume is off, a '*' (star) which I think means hot water only and finally a 'radiator' which I presume means hot water and central heating.
On my Vokerra is there another hidden switch, I cannot see it on the front plate - but it would be handy to know where it lives ...
There are also 2 temperature settings - To be honest adjusting these has never made any difference - the water is always too hot :)
Forgive me for my lack of understanding, but I thought the Danfoss TP 5000 was just a room thermostat with the option to set to the varying temperatures for different times. Eg - at 5pm set the room to 20 degrees and at 10pm set the room to 10 degrees ...etc. To just use the thermostat to control the temperature I would have to have the boiler in the permanent "on" position (not using the timer built into the boiler)
Is this what your suggesting or am I talking total b*ll*x ?
I am happy to replace the current thermostat with the one I have already but thought this would be in combination with a new timer.
Thanks for your patience
Steve
Sorry, my mistake. 80 SP has three positions as you say.
WRT the programmer. Temperature in the house is going to fluctuate. For instance it will rarely drop to 12 degrees C. So, the programmable roomstat is used to set for frost protection (say 12), background heat (when you are active in the house) say at 17, and say 20 when you are sitting down and reading a book or watching telly.
Temperature set to clock times that corresponds to your lifestyle.
DP,
A combi provides Hot water on demand, unless you have some non standard setup involving a hot water storage tank, the boiler will not fire up unless there is a demand for hot water, unlike a system boiler that will heat the storage tank. All you should require is a suitable replacement for the existing timer to control the central heating.
@MarkBarl
Mark,
This is basically the jist of this thread.. "can anyone suggest a suitable replacement for the existing (mechanical) timer"
I have come across landlords who restrict hot water to certain times of day to prevent their tenants having use of hot water at any time!
