replace valve on tricity bendix dishwasher?
19 Feb 2011
Wiltshire
I have been told i could have an air lock in my dishwasher from when i put it on its side to move it, which is why it will not fill with water.
Can anyone tell me how i first locate the valve. Then how do I try to unlock the valve and if that does not work how i fit a new one?
The valve is located just inside the machine the water inlet pump screws onto it, meter the coil on the valve for continuity disconnect the wire going to the valve first.
Also check to see if you have water going to the dishwasher.
